Integrate Labview into OpenBravo
Our company would like to integrate Labview into OpenBravo [www.openbravo.com] and open source, java-based application.  OpenBravo is a complete financial, accounting, budgeting, ERP system that we will use to control most of our facility.  Labview will control our algae reactors.  Can this be done?
Thank you,
Jim McMullan, CFO
Algae to Omega
(4,327 Views)
What do you mean by integrate LabVIEW into OpenBravo?
Sean N
Applications Engineering Specialist - Semiconductor Test
(4,300 Views)
Allow us to read some of the data generated in LabView [written in C] in OpenBravo [written in Java] such as algae counts and production outputs.  This will allow to do better forecasting and budgeting.  LabView will control operations for 30 algae bioreactors.  We need to track our high value byproducts [$2,000+ per kilo] down to the kilo due to loss and theft concrens.
(4,284 Views)
Accepted by topic author algae2omega
You could store the data from LabVIEW into a spreadsheet and then use that in OpenBravo.  Not knowing anything about OpenBravo makes it difficult to know how to interface with it, but LabVIEW offers various ways of saving the collected data, that can then be called to or referenced by OpenBravo.
Sean
(4,279 Views)
You may be able to simply use a client/server model and use TCP to read values from a LabVIEW application running as a server. You could implement a simple messaging protocol for passing the data between the two applications.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,268 Views)
Both sound like good ideas.  I have the OpenBravo programmers/engineers in contact with the LabView team as well.  Finding a solution right this minute is not the goal.  Knowing that there are several options and that it can be done, helps me make a decision since my company and my team need to live with the results for some time to come.  LabView is a definite purchase in the immediate future - our Chief Scientist insists on it.  OpenBravo is now as well.
Thanks for your feedback.
(4,254 Views)
I have no idea what the background of your LabVIEW team is but for this project I would highly recommend that you get some very experienced LabVIEW people involved to help design the architecture. If you don't have someone on the team with this level of experience you may consider getting a contrators assistance for a short time. Since you mentioned that they will "live" with this for a while you want to make sure you have a solid architecture and application that will be easily maintained and enhanced.
Mark Yedinak
LabVIEW Champion
(4,251 Views)
