Integrate Python Script in Labview
I want to integrate Python into LabVIEW the following way:
I'm using this python library called DeepLabCut-live. My LabVIEW software is recording mice and I want to track it real time using deep learning (hence DeepLabCut-live). However, in order to do so, I have to initialize the neural network before I run it. As far as I'm aware, calling a python node in LabVIEW resets the python script every time, so I'd have to reinitialize the neural network every time.
Is there a solution to this problem?
(1,595 Views)
I haven't done much with Python in LabVIEW. But, I believe global variables will persist as long as you keep the python session open in LabVIEW.
(1,574 Views)
