Integrate the PmodKYPD into calculator
I am trying to integrate my Pmod KYPD into a basic calculator. I have made a VI (keypad interfacing) that reads the input buttons from the keypad into labview, but only the buttons. I like this code (calculator 2013) I found of a basic calculator function from LanxiZ, https://forums.ni.com/t5/Example-Code/Mini-Calculator-in-LabVIEW/ta-p/3516347. However, this code is strictly software. I have been trying diligently getting these two codes to work together with my Pmod KYPD. Any ideas or feedback is appreciated!
(1,841 Views)
Which buttons are you planning to use for  +   -   x   ÷   =   keys?
(1,797 Views)
A for division. B for multiply. C for subtraction. D for addition. E for enter. F for clear.
(1,785 Views)
replace the software buttons with hardware buttons in the code.
If this is a class project, you should be doing the work.
(1,767 Views)
