03-22-2021 09:48 AM
I am using the GPS Demo code available on NI website and I have connected as following:
Myrio VK16E GPS module
5V 5V
GND GND
UART RX TX
UART TX RX
I already checked, it connects with myRIO fine and the code runs, but I'm getting random values from NMEA Sentences and nothing is being saved in Longitude and Latitude.
Solved! Go to Solution.
03-22-2021 12:59 PM
Could it be that you dont have any GPS signals were you are.
As you get a V in status, your GPS receiver do not have any GPS satellites in site.
03-22-2021 01:01 PM
Is there any way to check for sure if that's the problem and if so what should I do ?
03-22-2021 03:30 PM
Bring it outside, or at least near a window. GPS is difficult/impossible indoors.
03-28-2021 04:06 AM
Thank you, trying it outside worked
