Integrating Google Maps Streetview in LabVIEW
Can Google Streetview be integrated and viewed in a LabVIEW VI? I have location coordinates along with heading information and was wondering if I could use LabVIEW to depict that together in a VI.
Thanks!
(6,060 Views)
(6,053 Views)
Thanks. I came across this code, but this shows the sky view (view from the top) plot. I was wondering if streetview can be added to the VI based on heading information.
(6,016 Views)
Okay, I read the requirement for Google Streetview API and so far, there is no such thing as a Static Streetview API (similar to Static Map API that is out there) as of now.
Streetview is based on Adobe Flash and LabVIEW can integrate flash through ActiveX.
I came across this simple example at: http://code.google.com/apis/maps/documentation/examples/streetview-simple.html and the source code behind it is attached.
Now, I can create similar code using LabVIEW (with begin/end tag etc). But, I am not sure how I can really integrate that code to get a webpage address that could be embedded in FrontPanel ActiveX control.
Comments/suggestions are welcome. Thanks!!
(5,974 Views)
I found out a way to make this work (till some form of static streetview API is available). The source html file (along with the java script) can be passed as a local htm file to the URL input of the iWebBrowser2 and viola...
Once the location related parameters are specified, street view would work like a charm. Although this would return something only if Street View images exist (e.g. public places, major streets etc.)
Happy mapping!
(5,875 Views)
Hi
see here map in labview
M.Garousi
(4,929 Views)
