03-19-2009 08:20 AM
I got a signal from an antenna and sent it to the DSO. From the DSO, I sent the signal to SignalExpress and saved it on harddisk. This thing had to be done for 5 hours. The frequency at which i got the peak was 74MHz(which was desired). Now I want to integrate the total power in the bandwidth of the antenna. So I took the fft of the signal on labview and sent it to filter so as to remove the frequencies outside the bandwidth. Now, all i want to do is to integrate the power in the bandwidth and store it in a file as a function of time. Can somebody help me with this?
PS:I dont have an Integrator function in my toolkit(can it be downloaded?).
03-19-2009 08:32 AM - edited 03-19-2009 08:34 AM
Take a look here. But it is also easy to program such function. Just Google numerical Integration
03-22-2009 08:19 AM
03-22-2009 06:35 PM
If i just send the output of FFT function to a file, would it be stored?
I guess I don't understand the question.
A file stores whatever you write to it.
