Integrating a frequency domain signal
Hi
I am trying to extract the response of a frequency dependent signal :
1. First, I use the SignalFFT vi to get into the frequency domain.
2. Then I plan to integrate the FFT signal around a certain frequency and take a ratio of that wrt to the integral over the entire frequency spectrum to get a measure of how strong the signal is around that frequency.
I am choosing a range of frequencies above because the physical phenomenon producing the time domain signal produces a certain lifetime width. I need a numerical integration VI that can do step 2 above. The numerical integration VI that I found in Labview (using ver. 7.1) integrates the whole signal, and there is no way to define limits between which the numerical integration should be carried out.
Any ideas ?
Thanks.
(5,050 Views)
Hi m-s,
The numerical integration.vi gets an array of doubles as a input, why don't you try to use the Array subset.vi to only integrate the part of the signal you are interested in?
Tania Lozoya
(5,048 Views)
Thanks for the hint. Now how do I find out which array indices correspond to those limits ?
(5,042 Views)
That a cool question!
This has to do with the sample rate, when you adquire the signal, you get set of samples, that hava a sample rate, and when you do an FFT on those samples, every sample corresponds to frecuency bin (kinda of frecuency samples). Example:
If you get 100 samples at 1kHz, you will get a 100 windows, this is 100 samples to represent 1kHz, however, only the half of the spectrum is valid, because of the Nyquist teorem, so this mean that from 0 to 49, you have a correct representation, from 50 to 99 you have a reflection of the spectrum. So in the first 50 "frequency samples" you have 0-500Hz
Tania Lozoya
(5,021 Views)
The length of you acquisition determines your frequency step size.  1 second of data gives you 1 Hz resolution.  100 ms of data gives you 10 Hz resolution, etc...
Randall Pursley
(5,006 Views)
