Here is a little more information about the application. I have used data aquisitions to aquire two AC voltage waveforms. I have rectified the waveforms, and summed the two waveforms together. Now I need to take a summation (running sum) of the resulting waveform. Accuracy is somewhat of a concern, as this running sum will be used to calculate a series of costs and usage characteristics.
Hope this helps by giving an idea of what I am looking to do.
I have tried to do the numeric integration, but I am having a problem getting the waveform to sample as needed. My other idea was to convert the waveform to (x,y) coordinates and work with that data. I'm not sure what the best way will be.
