Intensity Map, Cursor Position Problem ?
Hi All
I have an intensity map for 9x9 matrix and I display them. I am trying to come up with: A cursor moveable across the map. When it moves, it gives me the X and Y coordinates. It displayes the cell # too but I am not able to programmatically extract that using property or invoke nodes. Any suggestions ?
Thx
(2,818 Views)
One way of doing that is to use the cursor.position property node, that returns a cluster with the X and Y values. To get the Z value, you can create a reference to the corresponding indicator in the cursor, and extract the corresponding value.
See the attached vi.
Message Edited by chilly charly on 06-29-2005 04:02 PM
Chilly Charly    (aka CC)
(2,810 Views)
