Intensity graph Y axis form array of time stamp (relative simple problem)
I have a relative simple problem...
I have a 2 D array. So for example I have this array
1 2 3 4 5
6 7 8 9 1
2 3 4 5 6
I have another 1 D array of time stamp corresponding to each row of graph. So
1:00:00 1:00:01 1:00:02
Three time stamp for the given 2D array.
I'm trying to my intensity graph to show the Y axis as time. How do I do this? I have tried to set the offset to the first element of time array, but the graph turns black. Thanks.
(3,643 Views)
nvm I got it work.
(3,638 Views)
Hi d1sturbanc3,
I know you asked this question a long time ago but you could solve it ?? I have the same problem. if you can help me I would be very grateful.
Thank you!
(2,781 Views)
wow this is long time ago... I think you have to convert the time stamp toa double, and feed that as the offset. In the graph properties, you have to specify time format.
(2,771 Views)
you mean the property xcale.offset ?? tells me that I can not pass an array of doubles. if you can send me an example ...
(2,757 Views)
I just had an insight to what you told me and maker.values ​​property and he wanted me to come !!!
I was stranded for days. Thank !!!!!!!!!!!
(2,750 Views)
