Intensity graph with Z values displayed
I just wonder how this intensity graph with numeric values plotted on it (Figure 2) was made :
https://forums.ni.com/t5/kl3m3n-s-blog/Infra-red-IR-array-sensor-with-custom-board-and-Arduino-Nano-...
Do you have any idea ?
Thank you for you help.
Message 1 of 10
(5,233 Views)
He used the image overlay (property) of the graph. I think that was given as advice on one of his questions, but can't find it*.
You'll have to calculate the positions of the text (basic linear interpolation in X and Y direction), draw the text in an image, and put it in the graph.
* EDIT: maybe this one: https://forums.ni.com/t5/Machine-Vision/Draw-line-or-a-dot-for-a-specific-pixels-on-the-image/m-p/30... EDIT: never mind, that's about IMAQ.
Message 2 of 10
(5,218 Views)
I would put transparent array on top of intensity graph
Message 3 of 10
(5,188 Views)
I wouldn't. Smiley Very Happy
Spoiler
All kinds of problems... The numbers would be hard to get centered. The graph cursors don't work anymore. Scaling the array is a hassle. Changing the graphs scale would be impossible. Scaling the array isn't even possible to do right, as the array can only scale with multiples of the nr. of elements.
Message 4 of 10
(5,182 Views)
Have you considered using the annotations?
Ben
Message 5 of 10
(5,174 Views)
Thank you all for your solutions.
I’ve almost finish doing the solution with the front image. I will post the code once completely done. However I’m not a Labview expert so be kind with me...
I didn’t know about annotation, I will further investigate it seem very interesting.
best regards
Message 6 of 10
(5,169 Views)
You'll get credit for effort, and advice (you didn't ask for) for free! No downside!
Annotations are pretty neat, but I think there where some problems when using them in practice. I'm not sure, but I think they get sluggish when you have a lot (>50?) of them? Maybe that got fixed by now, worth a try.
Message 7 of 10
(5,151 Views)
I tried with 100 and set to a fix position via allow drag = false
is there an easy way to calculate a dynamic offset for the label position?
e.g. how to derive the width and height of one super-pixel?
Message 8 of 10
(5,141 Views)
Not sure if that is required, as the coordinates seem to be scale space... So .5 should be the middle.
Anyway, to go from scale space to pixel space, you have two options. There are methods Map Coordinates to XY and Map XY to Coordinates. That should do the trick, but you'll need to do some math as the coordinates are pane coordinates. So you need to subtract the graph area position...
The other way is to get the width and height of the graph area, and the min and max scale (those could be flipped!) and do the interpolation yourself...
For both methods, if you want a relative position (like an offset), you don't need a full linear interpolation, just a linear scaling.
Message 9 of 10
(5,135 Views)
BTW. The presentation in this thread is about the image overlay.
https://forums.ni.com/t5/LabVIEW/Plotting-Types/td-p/3687321
And note the hint that the code should be organized, as it intentionally isn't.
Message 10 of 10
(5,133 Views)
