Intensity graph
Hello everyone,
I'm working on my senior design project, I'm designing microwave imaging system where I'm scanning a defected sample using sensor and getting the voltage at each scanning point as analog input. the scanner have two encoders, for both X-Y axis and the values of the axis are displayed in array separately to show the sensor position.
I need to display all of these data in intensity graph, so X & Y axis will represent the position of the sensor and the intensity should represent the voltage values. I didn't know how create the intensity graph, I have attached the code as well.
(3,109 Views)
Hi Mariam,
the IntensityGraph expects a 2D array of values. Each dimension represents an evenly spaced axis.
So your task is to create an array of sufficient size. Then use your X and Y values to calculate the index of the corresponding element in the 2D array. Write the measurement value into this element…
(3,092 Views)
Can you please explain further?
(3,071 Views)
Hi Mariam8713,
Take a look at this forum post that has further explanation about how the intensity graph works!
Jiwhan S.
Technical Support Engineer
(3,043 Views)
