Inter (digital, TTL) pulse interval histogram
I would like to creae inter pulse interval histograms based on intervals between TTL pulses that vary quite a bit (e.g., shortest may be 0.2 ms to longest of 2 sec). I already have an equipment to produce TTL pulses which can be fed into PCI-MIO-16E-4.
(3,133 Views)
Are you asking how to do a time measurement or how to do a histogram?
(3,133 Views)
You have no idea how tempted I was to just write: "Sounds great! Good luck!".
www.vartortech.com
(3,133 Views)
To Mr. Knutson from the original questioner
Thanks for your reply. I was asking how to do a time measurement. Please reply. Thanks
(3,133 Views)
Hello;
I'm attaching a Labview example which performs a histogram, but it uses diferent National Instruments hardware than you have.
Hope this helps.
Filipe
(3,133 Views)
