Inter module data transfer in FPGA
Hi everyone, i am working on a project in which i have PXI system with 8135 RT controller, 7854-R and 7951-R modules.
I am having a PID loop VI running in 7854-R fpga card.The output if PID is sent to RT vi every 10 micro sec.
In RT vi the values are passed to 7951-R vi, where based on these values a PWM signal is getting generated.
The problem is if i pass the values every 10 micro sec, i am not able to generate PWM signal, but if i change rate to 10 milli sec, then its working perfect i am able to generate PWM properly. Please anyone suggest me what i should do and tell me if their are any benchmarks for loop rates which i should consider.Please do refer the vi's if required.
Message 1 of 1
(2,571 Views)
