Interactive SubVI panel opening
I wish to know if is it possible to open and close a SubVI panel while this runs continuously because is making a plotting data at the same time that it arrives from a wireless sensor network. I would like to have the possibility to open or close the graph.subVI but I do not want to stop this subrutine because the data has to be plotted without lossing graphical data.
If someone have some useful idea please tell me. Thanks a lot.
Oriol from Catalonia
(3,631 Views)
You can use the FP Open property node. If you create a property node and wire in a reference to that Vi you can set the boolean FP Open value to true and false. I use it with a TCP/IP server to show and hide the front panel of the server for debugging purposes and it runs fine without stopping the application.
Hope this helps.
-Dave
(3,628 Views)
Here is a little example of what Dave is referring to.
Joe.
"NOTHING IS EVER EASY"
(3,622 Views)
I am sorry I forgot to say that I am working with the 6i version (student version). I can not open your example library.
(3,621 Views)
Thank you, finally I could open the example library, now I have used the property node to open the subvi.
(3,614 Views)
Try this.
Joe.
(3,610 Views)
