Interactive filter propositions with listboxes
Hello, I am trying to find a way for users to filter data by clicking on what they want / what they don't want.
I've achieved that thanks to 3 listboxes. Two of them are linked : when the user select one parameter name, it's different possible values appears in the second list box.
My problem is due to default values : when the VI is started several times, a given value is highlighted in blue on the listbox, but when the user clicks add, this value is not reported in the filter
Maybe I should clear the highlighted cell at VI start (but how ?). Or maybe should I work on listbox actual values instead of event "new value" ?
thank you in advance
best regards
(3,331 Views)
Accepted by topic author haha1234
Change selection mode:
And you can clear selection by -1
And finally you can build string without local variables
(3,291 Views)
Thanks, the Val(Sgn) tips works perfectly for clearing selection at startup of the selection pop-up.
(3,281 Views)
