Interactive system exec session
I need to run a separate executable through cmd in my LV application. Is it possible in any way to interact with the command line while it is executing the external program? I would need to start the executable, then read it's output (stdout) while executing and when I see a certain string, do something else in my LV app in order for the executable to continue. I know it is possible to achieve this by using a fixed delay and act after the delay to allow the executable to continue, but that is not a very robust way.
I searched around for answers but could only find either really old threads or not dealing with the exact same situation. Most answers related to piping(?) and .NET if I understood them correctly. As always, any help would be appreciated.
(5,769 Views)
Thanks for the links. I guess i'll have to study the subject and see if I can make it work.
I also realised there is a way to read the system exec output in real time, by directing the output to a file. In my case it could be enough to read the file while it updates, since I don't really have to input anything more to the executable.
(5,694 Views)
Have you had any luck finding an answer. All Windows Pipe code seems to have vanished.
(5,376 Views)
I ended up using the solution where I redirect the output to a text file and poll the file. It was enough for my case. For the polling you have to open the file in read only mode. Sorry for late response 🙂
(5,342 Views)
