Interface Wireless Vibration transmitter with arduino using specific frequency range
Hi, Any best suggestion to test wireless vibration transmitter readings by setting at a different frequency range of an XBee s2c-pro module? I want to interface this sensor with Arduino and set some specific range rather than making it work on default ones.
Any suggestion to make this possible will be much helpful.
(2,781 Views)
Hi, Any best suggestion to test wireless vibration transmitter readings by setting at a different frequency range of an XBee s2c-pro module? I want to interface this sensor with Arduino and set some specific range rather than making it work on default ones. Would it be possible to test by using LabVIEW
(2,788 Views)
Why are you asking here instead of the Arduino forums ? ? ?
Makes no sense.
(2,753 Views)
