Interface between Matlab and Labview
I am looking for someone who has experience with parameter settings before running a VI using ActiveX in Matlab.
(3,845 Views)
Hello BaWy,
I don't have any experience with this myself, but I might be able to help you if you could give a little more information. What specifically are you looking to do and what do you need assistance with? If it's specifically with the third party software then it might be more helpful to check Mathworks' resources to see if they have any documentation on this.
Jake A
National Instruments UK and Ireland
(3,783 Views)
Thanks for your help JakeA. I have made a measurement program in Labview. With exception of setting input variables i have to repeat the same algorithm. Because of the fact that I am more familiar with Matlab and because I also do some analytical calculations with the same input variables. I want to write that iterative 'run/stop/repeat' algoritm in matlab.
(3,770 Views)
Hi BaWy,
I think the following tutorial may help you to establish how to do this: https://forums.ni.com/t5/Example-Program-Drafts/Calling-LabVIEW-VIs-from-Other-Programming-Languages...
You may also need to look at the support resources for your third party software, since it sounds like you're looking for assistance with writing that code.
Jake A
(3,764 Views)
