Interface of Allen Bradley PLC with LabVIEW using TCP\IP modbus protocol
Hello.....
I want to connect a Allen Bradley PLC with LabVIEW using TCP\IP modbus protocol.
The PLC which I am using is a series of 1766BWA (Allen Bradley) please can you help me for the same or please give me suggestion.
Also I want to know the resistance values of this PLC.
Thank you.
(5,105 Views)
Here is a starting point:
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019 (Modbus for Labview)
Marco
(5,092 Views)
Hello
I was trying for connection of a Allen Bradley PLC with LabVIEW using TCP\IP modbus protocol.
Here i am attaching the snapshot of PLC interfacing and communication vi using modbus but it is not working
For reading we use setting shown in CHANNEL 1-modbus but it gives error regarding modbus addressing
and for writing it shows error illeagal address plaese help me for the same
Thank you.
(5,066 Views)
Hello
Here I am attaching the snapshot of PLC interfacing and communication vi using modbus but it is not working
and for writing it shows error illegal address please help me for the same.
Thank you.
(5,057 Views)
Did you know that you can talk directly to the PLC via either net using this toolkit?
https://www.ni.com/en-us/shop/product/ni-industrial-communications-for-ethernet-ip.html
Or if you think the $500 price tag is ridiculous you can make your own like I did. You do not need modbus.
Tim
GHSP
(5,050 Views)
