Interfacing ATMega32 with labview for temperature monitoring
Hi
i want to interface my labview with ATMEGA32 programmed in C
what i have to do ?
how is it possible ?
i am new one
i already interface arduino with LAbview
now what i a=have to do for atmega32?
kindly help me
(3,012 Views)
Try LINX. or you have create library and use it
Thanks & Regards,
Bharath Kumar
GCentral
(2,960 Views)
Thanks Bro...
But still i am in problem how to fix it
(2,944 Views)
Hi Muneeb,
"Fix" what?
You already got a solution to your problem in your other thread
(2,937 Views)
@Muneeb007 wrote:
Hi
what i have to do ?
i am new one
kindly help me
I would just use the Atmega32's on-board UART and the proper logic level USB to Serial converter.
Then communicate with it in LabVIEW using VISA exactly the same way I would communicate with any other instrument on a serial port.
In fact this should be easier as YOU are in full control of the code on the Atmega so YOU get to decide on the serial protocol, what the commands, and responses will be instead of being at the mercy of someone else's idea of how it should work.
=== Engineer Ambiguously ===
(2,927 Views)
