Interfacing LabVIEW with Meta Morph Journal
Hi
I'm just starting a project where I must fully automate an experiment involving a microscope and a microfluidics manifold. I am planning to use LabVIEW to control the manifold and Meta Morph Journal to program the motions of the microscope stage and I'm wondering if it's possible to interface the two (i.e. have one talk to the other to coordinate the actions).
(3,960 Views)
If you have one talk to the other why do you even need LabVIEW?
(3,954 Views)
Oh sorry I meant have Meta Morph talk with LabVIEW or vice versa (i.e. the programs talking to each other), not the devices themselves
(3,952 Views)
What are the interfaces on these two pieces of equipment?
How are they controlled?
(3,948 Views)
I have my joystick attached to the microscope that controls it motion.
While, I want to control it through Laptop Arrow Keys, so I was thinking if I can build any .vi and do so.
Will really appreciate if someone can guide us.
Best Regards,
Shaheen.
(3,913 Views)
Hi Shaheen,
You can get started by followind this tutorial which explains how to add your instrument so that MAX can see it and establish communication with the device.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(3,898 Views)
I will read this document and get back with you.
Thanks for kind suggestions.
Best Regards,
Arafat.
(3,891 Views)
