Interfacing Labview 8.2 with Beta/LaserMike Model 183
Hello:
I am trying to interface Labview 8.2 with Beta/LaserMike Model 183. The LaserMike 183 is a rotating chuck optical micrometer that takes outer diameter readings. I have connected the LaserMike to a COM port. Now I must take care of the software side. Will I need to request/create a driver in order for Labview to recognize the LaserMike? To configure the device, should I use the Instument I/O Assistant? I am not proficient at Labview, if any one could provide me with a step by step walkthrough of how to get my device configured and running, I would appreciate it. Thanks.
(4,487 Views)
You don't have to have a driver but you can request one here. The Instrument I/I Assistant could be used or you could write something of your own. There are shipping examples of serial communication. Just open the Example Finder and do a search for serial. With the programming manual, see what you can get to work. I would recomend that you first try to communicate with the instrument with a program like Hyperterminal before trying to write any code. That way, you can debug any problmes you might have with com settings or the cable type.
(4,479 Views)
