Interfacing Microchip ICD3 With Labview.
@Ranjeet_Singh wrote:
I tried. its working with IDE but not with command prompt..Can you share your VI in 2011?
Sure, here you go.
Message 11 of 50
(4,579 Views)
Here is mine. Let me know if any mistake is there
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 12 of 50
(4,572 Views)
After I run your VI. it says "Enter Target power"
--Ranjeet
Message 13 of 50
(4,569 Views)
right, the /V argument needs a spesified voltage, altho this argument is only needed if you don't have an external power supply for the chip your programing.
If you don't need the ICD3 to supply power just remove this argument.
If you do need it to supply power: Change it to "/V5" or "/V3.3" depending on what voltage your PIC needs. (setting the wrong voltage may damage the PIC)
Message 14 of 50
(4,560 Views)
When I am programming from ICD then I am using supply from ICD as I dont have power supply. One more thing as soon as I select programmer as ICD3 then status LED glow in ICd but nothing such happens when use LV.
--Ranjeet
Message 15 of 50
(4,558 Views)
After I change to V5 then it asks for enter hex file
--Ranjeet
Message 16 of 50
(4,554 Views)
Added 3.3V supply (Change it to 5V if needed)
edit: had a space between /F and the file path, should be work now.
Message 17 of 50
(4,551 Views)
no it not..Try something else
--Ranjeet
Message 18 of 50
(4,536 Views)
What errors do you get with the last VI i attached?
Message 19 of 50
(4,534 Views)
It says
Device not found
Initialize Failed !!!
and I channged it to 5.000 later but same thing
--Ranjeet
Message 20 of 50
(4,532 Views)
