Interfacing Sick Tim5xx with Myrio USB lidar
Hi. I'm trying to interface a Sick Tim3Xx and tim5xx via USB to the myrio and I'm having no luck getting it identified as a ttyUSB* or Ttyacm* I see usbdev1.2 in /dev/ And in Mac I see it as a Usb0 raw and it it is "not present" Is there something I have to do to show it as a TTYUSB0 or can I possibly work with usbdev1.2? I'm running 2014 firmware and labveiw
(3,736 Views)
Are you sure your device is a USB Serial device? TTYUSB* is usually reserved for serial devices, and it may explain why your device is not showing as expected.
Additionally, have you installed software on your myRIO? You may be missing necessary drivers for serial communication.
(3,695 Views)
You should also post your question in the myRIO forums next time.
(3,691 Views)
Actually, please avoid duplicate posting.
(3,686 Views)
I've been told its a composite device.
And I've got the visa software installed.
I had trouble with the mobile version of the site and it didn't appear to post the first one...  Should I delete this one or the one in the myrio section?
(3,670 Views)
It may be worth reaching out to Sick to see if they have any Linux drivers for your device. It's possible that the myRIO doesn't have the necessary device driver to communicate properly.
(3,607 Views)
