Interfacing of RS232 serial devices through USB ports within LabVIEW 6.1 and Windows 2000 Pro?
I have a data acqusition requirement of using 5 RS232 devices, but the motherboard i use only has two serial ports. However, it does have 4 USB ports. Does anyone know if it is possible to use these USB ports to input data from an RS232 device through a serial to USB converter?
Does LabVIEW 6.1 support this under Windows 2000 Pro?
Thanks in advance,
Fraser
(3,199 Views)
No problem. Most serial to usb converters have a driver that makes them appear as standard serial ports, that way you can communicate to them just as if they were...
Check out:
http://www.gwctech.com/ebproductdetail.asp?id=47
or
http://www.digi.com/products/usb/index.jsp
(3,199 Views)
Not to mention NI's line of USB-232 converters:
http://sine.ni.com/apps/we/nioc.vp?cid=11371〈=US
(3,199 Views)
Hi Fraser,
I just moved an app to a new laptop and had to use a USB to serial comm adapter. At first try the app did not find the comm port.
After sleeping on it, we downlaoded the most up-to-date driver for the device and upgraded VISA to the latest and gretest version.
Everything worked fine after that.
Ben
(3,199 Views)
Ben
Thanks for the info.I'll try it!
Fraser
(3,199 Views)
