Interfacing to C code - Handle?
I need to create a LabView Interface to the following  'C' Call ....
Have you guys ever worked with passing Windows Handlers?
extern "C" bool WINAPI ConnectDevice(HANDLE  hnd, USHORT VendorID, USHORT ProductID);
I'm using Labview 6.1
(2,945 Views)
A handle is a U32. Windows API functions require the stdcall calling convention, but I'm assuming it will work in your C case as well. Look here for more details (and note the links at the top of the page).
___________________
Try to take over the world!
(2,940 Views)
