Interfacing with ADAC cards
Using LabVIEW with ADAC/5501mf-v card couldn't get DAC channels to output anything , looks like ADAC-lvi.con or ini file problem as am getting AL_SetDataCode error ! The configuration utility creates the files but still invalid, if anyone has those two files (adac-lvi.con and adac-lvi.ini) working properly for this card could u tell me the way ?
(3,147 Views)
What are you doing in LabVIEW to interface this third-party product? Are you calling a driver DLL or using a command line argument with System Exec? Is this a LabVIEW-specific issue or does your device driver software not work in any environments? What configuration utility are you speaking of?
From my experience on this forum, you'll have the most luck getting responses if you can be more specific about how your issue relates to LabVIEW.
Jarrod S.
(3,132 Views)
this product is  ADAC/5501mf-v  from IOTECH
that third party card has drivers (DLL) when labview calls some of these DLLs it keeps giving error codes in the return value (-ve error codes) and then the VI fails,
I expect help from a user who used a similar card, it seems to be a  problem with the INI file
(3,124 Views)
