Interfacing with Vernier
Hi, I am working on a blood pressure labview program. I wanted to know if there was a way to use an NI or normal DAQ device in conjunction with the following program that I constructe. The link below shows what the block diagram looks like.
(http://decibel.ni.com/content/servlet/JiveServlet/previewBody/3724-102-1-5881/Blood_Pressure_Daniel_...)
How can I alter the interface to include my DAQ device?
(3,230 Views)
Well, if you are familiar with DAQmx and the other hardware/functions, then you should be able to use something from NI. Do you have NI's Biomedical kit?
(3,228 Views)
No i do not believe i have the Biomedical kit.  Is this a downloadable program from NI?  Also is it possible to take out the Init VI in the program and just add a daq assistant to it and configure it?
(3,216 Views)
It's dowloadable from the link I gave you.  That was the whole purpose of providing the link.
I doubt that it would so simple but you will have to look at the functions in that other program to see what is done.
(3,209 Views)
