Interfacing with firewire camera that is not IIDC/DCAM-compliant
Hello folks,
I have a Retiga 2000R, a firewire camera which, as it turns out, is not IIDC/DCAM compliant, which makes it unrecognizable in MAX and thus unable to be relatively simply interfaced with via LabView.  I am already aware of the SITK toolkit for LV, which is for this purpose, but it is rather expensive, especially since it has a whole suite of functions I will never use or do not apply.
My question to you folks is this: how do I go about talking to this camera using LabView?
Cheers,
zob
(2,746 Views)
Can you get access to documentation for any of the camera's Driver DLL's from the camera manufacturer?
Most cameras have a relatively straightforward API designed to work with programming languages other than LabVIEW.  Getting at those functions in the DLL can be a bit of a pain with LabVIEW but it is doable.
(2,745 Views)
Thanks for the reply - I will look into that and see if I can get ahold of some documentation and report back.
(2,742 Views)
There is indeed an SDK and specifically documentation for the API available from the manufacturer.  Thank you for the direction - I'll probably post back here should (that is when, haha) a question arises.
(2,733 Views)
