Interfacing with freestyle power amp"mmz09312bt1"!
I wanted to virtual create an environment in labview for theoretical testing of "mmz09312bt1" ...Can someone plz let me know how to implement this in labview..as i have never seen a chip being called in labview(like pspice).the main aim is to change various parameters of the chip like "s parameter","noise figure:..nd stuff so that i can get my resultant o/p.
thanks in advance
(2,290 Views)
Accepted by topic author freescale
You would need to develop an entire circuit simulation program in LabVIEW, which you could do, but it seems like a lot of effort.  If you just want to test one circuit, you could draw up a circuit model and develop the equations for that model.  Then implement those equations in LV.
NI offers a product called Multisim (which I have not used) for circuit simulation.  There is a Multisim board on the Forum.  Posting there might get you information about whether that program could do what you want.
I have also played around at usign LV to develop a GUI wrapper around a free command-line-interface version of Spice.  It "sort of" works, but also takes a lot of effort.
Lynn
(2,280 Views)
thanks a lot...even i was thinking of implementing it the same way(eq way)...problem poped up when i didnt have equations,but i have various graphs....i guess i can get eq out of it,nd do the needfull.....moreover i did see multism(i havent worked on it)....but thought maybe i might be missing somethin coz lib r available for mcu(freescale)......will check ...
(2,276 Views)
