Interger to hex conversion ???
Hi
Is there a easy way to make interger (unsigned 32 bit ) to HEX
conversion ??
(2,987 Views)
Yes,
1.Just select from control Pull-down menu "format and precision" and
then "hexadecimal".
2.If you need string, use "To Hexadecimal" vi from string or numeric
palettes.
kristian@krause.dk wrote:
> Hi
> conversion ??
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
(2,987 Views)
Kristian,
It depends on what you want to do with the hex conversion. To view a
number in hex in a control, right click on the control, select Format &
Precision. As long as the format is set to numeric, you can select
between decimal, hex, octal and binary from the other drop-down list.
If you want to change an unsigned 32-bit number to a hex value to be
written to a file, you can use the String->Format Into String VI. Wire
your U32 into input 1, and set the format string to %4x (which will show
a 4 digit hex value). The output will be a string which contains the
hex value.
Hope that helped.
Mark
In article <39cf37ee.18376265@news.euroconnect.dk>,
> Hi
EX
> conversion ??
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,987 Views)
