04-26-2006 07:35 PM
04-27-2006 01:34 PM
Thank you for posting your questions to the NI Discussion Forums! However, I am unclear about what exactly you are asking here. Are you trying to take the mathematical integral of a signal in LabVIEW? Are you having problems configuring your DSP board? What version of LabVIEW are you using (number and package)?
If you clarify your question I’m sure that myself, or another community member will try to help!
05-03-2006 07:25 PM
05-04-2006
11:24 AM
- last edited on
11-12-2025
08:53 PM
by
Content Cleaner
Hello Bob,
I’m not really clear on what you mean by “integrate the message”.
If you are referring to a mathematical integration (as in take the integral of sin(x), then I would recommend using the built in mathematic/analysis VIs (some examples you might consider are “Integral pt. by pt” and “Sine Integral” for example). You never specified which version of LabVIEW and which distribution you were using, but all the VIs I see to perform calculus operations on signals are not in the base package. If you have the base package, I would recommend upgrading to the “full” or professional packages to get these VIs. There is also the possibility that other users have mathematics packages out there for use with LabVIEW that you could use. If you do have the full or professional version of LabVIEW you can find these by looking in the mathematics palette of LabVIEW in your Functions Palette. Also you can search for VIs in the functions palette. When I searched for “integral” I found about 6 related VIs that could help.
If you are using the word integrate in the context of “coordinating or blending parts into a functioning or unified whole” such as: “I would like to integrate signals coming from my signal generator with my DSP board using LabVIEW”, then I would recommend getting started by reading the tutorial about using the NI-DSP toolkit (http://zone.ni.com/devzone/conceptd.nsf/webmain/1785af6322548be186256cd7005ca819) and further clarifying the exact problem you are having with your setup. i.e. are you having problems getting the data from the signal generator? Is the data bad? Is the problem with communicating with your DSP? Are there error messages? Etc….
Were here to help! Please let us know how we can assist-
05-04-2006 01:59 PM
