Intermittant build error in LV 2009
Depending on the mood of my project I will sometimes get a build error for a windows app that indicates a 'bad connection' to
a ptbypt summation vi.  See attachments.  I can fix the problem whenever it comes up by forcing a recompile of the source code.
The question is why does this keep happening and will it ever stop?
(2,549 Views)
Hi Sachsm,
When exactly does this error occur?  Is it only with this VI?  If you do the same process with the MeanPtbyPt.vi can you cause the error then?  If you can, attach your project and describe the detailed steps you take to generate the error and I will try to reproduce the error.  Thanks!
Kristen H.
(2,519 Views)
