Internal Error
After installing Labview 6.0.2, when loading I get "Error #3 in memory.cpp in line 914. I have not seen this problem when loading on similar computers. I am running Win2000.
(2,844 Views)
Try reinstalling LabVIEW. You might also want to go to ni.com/support, as instructed in the error display and see if that helps. Otherwise, contact NI support. This shouldn't be happening, and is probably due to a problem during installation.
(2,844 Views)
