Internal/Private Property Nodes.
How can I acces to internal/Private Propertys?
Message 1 of 15
(2,286 Views)
To be able to view private classes/methods/properties, add key "SuperSecretPrivateSpecialStuff=True" to your LabVIEW.ini and restart LabVIEW.
More infos: https://forums.ni.com/t5/LabVIEW/How-do-I-enable-the-following-private-functions-in-labview-2014/td-...
Then for deprecated ones, you will need to configure your invoke/property nodes via scripting:
Raphaël.
Message 2 of 15
(2,265 Views)
Try putting SuperSecretPrivateSpecialStuff=TRUE in your LabVIEW.ini file.
Message 3 of 15
(2,260 Views)
I can't believe the name of the label that the LV developers gave to that parameter 🤣🤣
Every day, I am more in love LV
Thanks a lot!!
Message 4 of 15
(2,251 Views)
Here is a table of labview.ini settings that I made some time ago.
Message 5 of 15
(2,216 Views)
"funkyErrClustWire", at least, is long since rolled into LabVIEW.  In days of yore, error wires bore the default cluster wire color (magenta).  This token gave us the sickly yellow-brown we've all come to love.
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 6 of 15
(2,182 Views)
Hey paul,
there is an INI line that can enable RTL format it lv?
thanks in advance.
Message 7 of 15
(1,405 Views)
Hey paul,
thanks in advance.
I have no idea what you understand under RTL, there are about a dozen things that come to mind but none makes sense in this context. But my guess to this question is NO!
Rolf Kalbermatter  My Blog
Message 8 of 15
(1,393 Views)
right-to-left, top-to-bottom script (RTL) - writing starts from the right of the page and continues to the left, proceeding from top to bottom for new lines. specifically, I use Hebrew and English.
Message 9 of 15
(1,385 Views)
I'm not sure the INI settings will help. But I'm totally ignorant on that topic. tst would be the person who would likely know most about that as he used to write applications for Hebrew in the past.
Message 10 of 15
(1,371 Views)
