Internal Warning 0xF7CF2FC3 OMUDClassLinker.cpp line 4955 when launching built executable
After launching the built executable from one of my projects I get the following internal warning:
Error dialog boxError dialog box
Internal Warning 0xF7CF2FC3 :  'OMUDClassLinker.cpp', line 4955
LabVIEW version 20.0b.52
For assistance in resolving this problem, please contact National Instruments Support.
Log from %LOCALAPPDATA%\Temp is attached
Which points to: DWarn 0xF7CF2FC3: Must run UpdateAllDataDefinitionDependencies before calling this function.
The application still seems to launch and function correctly (not fully tested yet though).
I tried creating a completely new project file and build spec, and only adding the one file to the build, but get the same error.
Any ideas on what could be causing this?
Message 1 of 1
(1,759 Views)
