Internal error or crash at ExecSystem.cpp, line 1456
I'm getting this error message when running a VI that calls a .NET constructor.
I have no idea what this error means -- I attach here the error log file.
THanks!
Claudia
(2,698 Views)
Hi ClaudiaF,
What do you mean by .Net Constructor ? Do you mean .NET assembly ?
What was the framework for building  your .NET constructor ?
What is the framework install on the computer running labVIEW ?
I think you should  create a simply .NET constructor and try again. if with a very simply .NET constructor it doesn't work maybe there is a configuration problem.
Best regards.
(2,665 Views)
