Internal warning 0xAFBF5C57 on startup with LabVIEW 2011 Student edition
Upon opening LabVIEW 2011 student edition, I get the following error everytime I open it.
I am using the it on a Mac computer, with Mac OSX 10.7.1, the Lion edition operating system.
(2,744 Views)
(the error is in the picture file attached)
(2,743 Views)
Hi Joe,
Have you ever successfully opened LabVIEW 2011 on your Mac?
Also, can you tell me what processor does your Mac has? I want to make sure that there is not a compatibility issue here. Please reference to LabVIEW Version Compatibility with Mac OS PPC and x86 Processors for the compatibility list between LabVIEW and Mac.
Daniel
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(2,728 Views)
Yes I have successfuly opened LabVIEW 2011 on my Mac.
The processor is a 3.06 GHz Intel Corde 2 Duo
(2,714 Views)
Hi Joe,
What is most likely happening is that you have installed DAQmx base, NI-VISA, NI-488.2 or other 32 bit kernel modules while running Mac OS X on the 64 bit kernel, which is the default mode in which you start up. Please follow the following Knowledge Base article so you can load your Mac into 32 bit kernel mode, and test to see if you still get the warning before launching LabVIEW.
Daniel REDS
RF Systems Engineer
Help us grow.
(2,695 Views)
Please also go ahead and try to look for the log file error and attach it to your post so we can take a look at that error.
Daniel REDS
RF Systems Engineer
Help us grow.
(2,692 Views)
