Internet Developers Toolkit + VI Metrics
Hallo all,
I' am trying to measure the complexity of the G Web Server by using LV
6i Prof's VI metrics tool. Independent of opening "HTTP server" itself
or putting it on a diagram of a new VI it isn't possible to choose the
HTTP Server VI, because you can't get it over a Property Node choosing
Application:All VIs In Memory. Does somebody have an idea????
thx
chris
(2,917 Views)
If i undertstand this correctly you are trying to programmatically get the HTTP Server statistics. You can open a reference to the "HTTP Server" and later use the application ref to find out the VIs in the memory.
Abdullah
(2,917 Views)
