Interop .NET Assembly Build Error
Hi all,
I´m trying to generate a Interop .Net Assembly from LanVIEW. I got the following error:
System.ArgumentNullException in AB_InteropAssembly.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Is someboy familiar with this problem?
Esteban
(3,173 Views)
Hi Arroyo,
first of all, have you checked the help to this topic?
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/building_a_net_assembly/
Then the question is what Version of LabVIEW are you using and wich version of .Net is installed on your computer?
Could you be a bit more specific about this.
Tenshinhan
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(3,116 Views)
