Interpolate Pixel
@Andrey_Dmitriev wrote:
wiebe@CARYA wrote:
Well, that's not fair if you don't show the code 😉.
Unfortunately you didn't read my message thoroughly — the link was provided:
Re: Strange deviations of the intensities with IMAQ Flat Field Correction VI.
https://forums.ni.com/t5/Machine-Vision/Strange-deviations-of-the-intensities-with-IMAQ-Flat-Field/m...
Also attached to this message (sorry for off-topic) and this time downgraded to LV2018 (but 64-bit only), full C code inside.
OK, didn't make that connection.
But the zip shows IMAQ vs DLL, not plain LV code...? I thought we where comparing LV vs C here?
Your "Flat Field Image - Prepare.vi" call steals CPU from the IMAQ benchmark, as it runs in parallel of the benchmark.
Message 11 of 95
(2,451 Views)
wiebe@CARYA wrote:
EDIT: Not sure if you want to get 1 interpolated value from a pixel map, or interpolate the entire image. If it's the entire image, read on.
For larger images, you can use 2D FFT to resize (interpolate or decimate).
The trick there is that the amplitude needs to be adjusted by the resize factor.
I think this might be faster, but only at some point. The interpolation will be different, definitely not linear. Maybe better, maybe worse.
Another benefit is you can resize with any factor. After all, interpolating between pixels doesn't result in 2X the width\height. It actually resizes each dimension with (x-1)*2+1...
I'd have to dig if you're interested.
Here's what I have:
Guess as it is, it only grows the size.
If you don't have doubles as input, you'll loose a lot of the gain.
Message 12 of 95
(2,432 Views)
Oh, good catch, you're perfectly right! On the other hand, this Flat Field Image - Prepare takes just a few milliseconds (3-5 maybe on my PC), so it doesn't affect the overall results much, maybe just a few percent. I just overseen this small issue, sorry about that.
I feel myself slightly uncomfortable to bother everyone with non 2D Interpolation-related things, but anyway, in general, we're comparing different methods that lead to exactly the same functionality, but if you need to compare LabVIEW vs. C - why not? In the attachment — more or less correct comparison (if I've missed something, please don't hesitate to correct me). I increased the image size to 8192x8192 pixels to avoid the for-loop in the benchmark.
And it's still three times faster than LabVIEW:
And here is not so much room left to improve:
We can do this parallel, but in C - as well, so the overall ratio will remain (as long as memory's throughput will allow). Again, its not an advertising to rewrite everything in C, or ultimate statement "C is faster!", no, no, no at all, but in some cases you can win.
Andrey.
PS
And please take a note, I haven't used FMA (Fused Multiply–Add) Instruction Set here, which could improve C code a little bit 😉
Message 13 of 95
(2,429 Views)
@altenbach wrote:
Looks loosely based on this old code. I doubt you would need that much orange. I'll try a few things.
I actually didn't base it on anything.
Also that code has a bug: It assumes that paul_a_cardinale_0-1713450783762.pngpaul_a_cardinale_0-1713450783762.png rounds down; but it really rounds to nearest.
Message 14 of 95
(2,420 Views)
Nearest-neighbor interpolation is still interpolation 😁.
Faster Too!
Message 15 of 95
(2,413 Views)
Replacing the detour via DBL multiplication with a LUT approach, gives me about 3-7x speedup over the original code.
(Since the LUT is quantized to U8 values, it does not really need to be very big)
I'll attach some code later.
For example, the following 8x expansion takes about 100microseconds on my laptop (same result as yours). I am sure there is some slack left:
The LUT cosntant is created as follows:
Message 16 of 95
(2,391 Views)
Faster Too!
That was my starting point.  I wanted something more accurate.
To be extra fancy, it should take into account gamma (that would probably slow it down to a crawl).
Message 17 of 95
(2,390 Views)
Also that code has a bug: It assumes that toI32 rounds down; but it really rounds to nearest.
My old code only convert to I32 after rounding to -Inf. No bug.
Message 18 of 95
(2,386 Views)
In my code, all you probably need is a nonlinear LUT to take gamma into account, but I have not tried that.
Message 19 of 95
(2,383 Views)
Interesting, what exactly do you mean? I haven't much experience with color images, so my idea could be wrong, but probably 2D interpolation in color mode other than RGB will help, like in HSL?
Message 20 of 95
(2,374 Views)
