Interpolate one 2D array to match the size of a 2nd 2D array
Dear all,
I have two 2D arrays containing spectrometer data (read from txt files via "read spreadsheet" vi).
X values = wavelength (from 400 - 700 nm), Y values = corresponding amplitude.
Problem:
Spectral data have been recorded with two different spectrometers with differing resolution.
Array1 = 1609 data points in the  400 - 700 nm range.
Array2 = 713 data points in the  400 - 700 nm range.
How can I interpolate array2 in order to make it 1609 data points as well?
(I need to do calculations with both spectra hence array size need to be the same)
Thanks a lot,
Holger
(1,508 Views)
Have you checked this example: C:\Program Files (x86)\National Instruments\LabVIEW XXXX\examples\Mathematics\Interpolation\1D Interpolation.vi ? I guess in your case you need to play with xi value, so it will be possible to scale it up to 1609 points.
(1,476 Views)
Accepted by topic author 4Holger
Thanks a lot for getting back to me, kosist90!
In the meantime I found a powerful yet simple solution using the Resample Waveforms Single Shot vi.
For those interested, I attach a screenshot.
Thanks again, Holger
(1,471 Views)
