Interpolate
Hi, guys! (and girls 😉 !!!)
Ok, I´ve a test system and I want to apply a calibration. I store the losses in a text file for the 3 signal generetors in a file, for a range of frequencies wich I can set (example: 0 MHz to 1000 MHz in 100 MHz step)
It´s working with no problem, as far as i run my test with the same frequency settings, but not when I run with a different one (for exemple, with 125 MHz) It´s clear that has no sense to make the calibration for each possible frequency. How can I do to interpolate the value, saying to Labview to look for the nearest value (either upper or lower).
Thanks in advance!
(2,860 Views)
See the attached vi,
There it is done in some different ways.
Hope it helps,
Paulo
(2,845 Views)
Perfect, man.
Thanx!
(2,842 Views)
