Interpolation of "Y" value based on a "X" value from a table..
I have a look up table as below of a non-linear function :
X-Value Y-Value(low) Y-Value(High)
500 5.6 6.0
1000 6.8 7.3
1500 6.9 7.3
2000 7.2 7.5
2500 7.5 8.0
3000 6.8 7.4
3500 6.3 7.0
4000 6.0 6.9
In real time I am plotting both X and Y values from the field. And for every X-value actual ( sampled once every 50ms),I have to use the above look up table to find if the Y-Value satisfies the condition
Y_Val(Low) < Y_Val(Actual) < Y_Val(High).
I have been reading other posts on interpolation in this forum also. And tried using the 1-D array interpolation with some gimmicks. But still the final and maybe an elegant solution eludes.
Thanks for your time.
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(2,996 Views)
Hi Raghunathan
I had a similar problem recently.
The following .llb has two VIs. The SubVI calculates the interpolated Y values.
The main VI checks your actual Y value against these limits.
I've defaulted the values to those you supplied.
Hope that helps.
(2,986 Views)
Correct me if I am wrong, but why do you need an interpolation if you only have a strict comparision?
For me it looks like a standard soft-triggering. If so, try to look into LV examples on triggering and you will find a lot of useful functions to do a soft-triggering for you.
hope it helps
Pawel
(2,981 Views)
@NeilR wrote:
Hi Raghunathan
Hope that helps.
Dear Neil,
Thank you so much.
I took the sample code that you had posted and just added upper and lower bound checking before I used it.
Does what it is supposed to do.
Regards
Raghunathan
Raghunathan
(2,962 Views)
