Interpret 3d model
Ok this is way to complicated for me and I need a lot of help.
What I am looking to do is. Taking a 3d model such as STEP file, or IGES, or BMP. And practically make G-Code (IF I understand it my self.)
the end result should be a way to move 3 motors to get one point to trace the object. For use in a computer controlled 3D Printer.
 I don't want it to be G-Code because then I will need to interpret G-Code. I would just want it to be motor position values. And if possible material selection values.
(3,002 Views)
Can I get a bit more information about what you are trying to do? You mentioned using G-Code. Were you planning on integrating your G-Code with LabVIEW? Currently, NI does not support the direct integration of G-Code into LabVIEW. What were you planning on doing once you generated your G-Code and what were you hoping to accomplish using LabVIEW?
Also, are you looking to use NI hardware to move the motors? If so, which products will you be using?
Stephanie A.
Americas Marketing Manager
(2,976 Views)
