Interrupts for Line Following Robot
Hi all, I have assembled the a rover robot to build a line following robot using Pitsco Tetrix Prime myRio. Now, what is left is programming it using LabVIEW. I am just wondering whether I will ever need to use "interrupts" in the software or not. Any thoughts!! Thank you
(2,624 Views)
There are many software design plans that you could follow to accomplish this, so asking if you will need "interrupts" isn't really possible to answer, but if you do. The way Interrupts are used in LabVIEW is called Event Structures, so if you need info on interrupts search the internet for event structures. Good luck!
(2,578 Views)
