Interupt programming in Labview
Hi
I wonder if it is possible, like microprocess programing ( assember ), to
make and interupt to stop the process and begin to work with the new task
with higer priority?
If it's possible, where can i get an example to learn more about it.
Thankfull for help.
Björn Lindegren
(3,555 Views)
It is possible to assign a priority to different VIs.
If a VI is running, and a higher priority one becomes
ready to run, it preempts the lower priority one.
This is done using OS threads, not interrupts, but
it will have a behavior similar to what you are asking
for.
For examples and info, look up Execution System Priorities.
Greg McKasle
(3,555 Views)
