Invalid Device Error when using Labview to comunicate with Jorway 73A
I'm having a problem when trying to get Labview to communicate with the Jorway 73a CAMAC crate controller. Keep in mind while reading this that I'm still fairly new to both the CAMAC system and Labview. I've downloaded the drivers for the Jorway 73a off your site and run into a "Invalid device" error whenever I try to read or write from the CAMAC crate using the read or write VI's. Oddly, the initialize/clear/inhibit VI runs without error. When reading cmjwdll.c I can tell that this error occurs whenever "the device selected is not a JW 73A". Not sure why I'd be getting such an error, and only with the read/write VI's, not on the initialize/clear/inhibt one.
Thank you for your time.
(2,963 Views)
Hi Caleb,
You may want to contact support@jorway.com for this question. Looking at the driver (http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/398258c61da17663862568ab005fbcbc?OpenDocument) It states that these drivers use 32-bit dll's that only work on 95/NT and are provided by Jorway.
Hope this helps out!
Best Regards,
Aaron K.
Application Engineer
(2,963 Views)
