Invalid Input parameter warning when connecting to the .vi through a remote panel
My program seems to work fine except that occationally when I connect to it via a remote panel, the program will crash and give a warning about having an invalid input parameter. It doesn't seem like an error related to a remote panel connection but I only get it through a remote panel. I haven't been able to recreate the problem accessing and interacting with the program at the host computer.
Any suggestions,
Cheers, Derek.
(3,066 Views)
Hi, Derek.
Just to make sure I've got the facts straight, let me repeat back to you my impression: you're creating a remote front panel using the Web Publishing Tool, running the LabVIEW web server on computer A, and then trying to access the VI remotely from a web browser from computer B. Doing so causes something to crash. If you access the VI through a web browser from machine A, there's no crash. Am I correct?
On top of that, let me ask you some other questions:
What OS are you using (on both computers)?
What version of LabVIEW (on both computers)?
Have you loaded the corresponding version of the LabVIEW Run-Time Engine on computer B?
     If not, try that and let me know what happens.
     If so, please go to Control Panel>>National Instruments Software>>Edit on both machines and tell me what versions of the run-time enginer are listed.
Does this hapepn with more than one VI, or is this the only VI that causes the problem?
Tell me more about the crash:
Does the web browser crash, or does the plugin/VI crash within the web browser?
How far does the remote panel get before the crash occurs?
     Does it crash before the frame appears, or does the download progress bar appear?
     Does it fully download?
     Can you see the front panel?
What browser are you using? What version? Is it the same browser/version on both computers?
Let me know. Have a nice afternoon!
Message Edited by sarahk on 07-11-2006 02:48 PM
Sarah K.
Search PME
(3,057 Views)
